equation
hello everyone I try to use help quick sheets and I wrote the following eq but I get the red line almost for all the results and I do exactly step by step im sure there is something missing here but I can not find it could you check it out and let me know what's is the problem
plz check the attachment
LucMeekesAnswer
23-Emerald V
Please attach your worksheet containing the equation.
Emeritus
Hello @kakomoji323
What product is this in reference to?
Thank you,
PTCModerator
LucMeekes23-Emerald VAnswer
23-Emerald V
thank you for response I figured out , and I wrote it down,  my question is ,  how this output plot change depend on R value,  I  mean I would like  to add   variable value of R from 0.1 to 5 ohm  . in attached file r is fixed but I want make a loop with 5 different value of R  .
thank you in advance
