Equation solving challenge-Filtration
- 4 replies
- 3187 views
- Translate All
Hi everyone, for a second time I’ll ask for your help, I still working on a particle retention research and I would be really thankful if someone could help me out with this.
Let me explain the situation: I need to solve an equation that allows me to match experimental data to the Filippov model and here begins the problems, the experimental data represents a discrete distribution for particle and pore size distribution, but the Filippov model used a continuous log-normal distribution function for particles and bilog-normal distribution function for membrane pores, I’ve been trying to use the “dlnorm” function from Mathcad but I suppose that something is wrong because it doesn’t work like it supposed to do. I’ve been reading a paper that claims to solve the integro-diffrential equations for flux J(t) and for the injected volume V(t), this paper however, does not give much detail about it.
Thank you in advance, I am open to advices related to this particular challenge.
