Equilibrium Stages Required to Separate a Propane/Pentane Mixture
- November 18, 2013
- 0 replies
- 2151 views
Description:
A propane-pentane feed at 10 bar is to be separated in a multistage distillation unit to a required purity of both components.
This worksheet will calculate the required number of theoretical stages required. Data describing propane-pentane equilibrium composition is supplied.
