Werner_EAnswer
Feb 22, 2023 9:35 PM UTC
As far as I remember we already have discussed this problem in the past here in the forum.
The conversion fails because of the hash (#) in the file name. The converter seems to be unable to write files with that character in the name.
So rename the files avoiding the character # and the conversion should work OK.
EDIT: Just found the old thread
https://community.ptc.com/t5/Mathcad/Mathcad-15-to-Prime-Conversion-Failing/m-p/793954/highlight/true#M200949
I would have thought that was considerably longer ago.
Nevertheless, I think this is a bug and if you feel like it, you can report it to PTC support.
23-Emerald V
Feb 22, 2023 6:46 PM UTC
Correct (that is, I checked the Case 1 file) comes with fail, and no clue as to why.
Contact PTC customer support.
Feb 22, 2023 7:10 PM UTC
Thank you for your quick look at this issue.
Will contact PTC Support as you suggest.
Feb 22, 2023 8:24 PM UTC
Don't know why, but I think I could convert "Case 1" by
1. using Cntrl/A to select entire worksheet
2. past into a new worksheet
3. converting the copied worksheet.
Haven't a clue why this seems to work, but conversion of original fails.
Werner_E25-Diamond IAnswer
Feb 22, 2023 9:45 PM UTC
Thank you!
It worked like a charm.
