Error Plotting a Function
- 4 replies
- 3233 views
- Translate All
Hi
I am fairly new to mathcad and I'm having a problem creating a graph of an equation, which describes the transient behaviour of the torque generated by a moter during a fault condition. The datasheet where the equation comes from states that the maximum value (-295.4) occurs at t=0.016s and so I have been able to check that the equation is giving the correct answer for a single value of t.
I now want to create a graph of the function, but when I try to do so, I get an error stating "Plotting failed. Replace complex values and NaNs by real numbers".
Can anyone tell me why this is going wrong? I have tried it with and without units; using t and t1 as the argument.
Ken
My Mathcad Prime 3 worksheet is attached.
