error plotting matrix values
Good morning,
i need an help to solve a problem with a plot of a 0-column of a matrix.
Attached to this message there is a mathcad file whith this problem.
Thank you
Mario
terryhendicott
The data files also have text at the bottom of the file and some blank lines.
You need to dump these two non-data lines using the submatrix statements or they appear in the matrix as text elements.
******************** END SESSION 22/08/2019 09:14:58 ***************
This seems to fully populate the graphs.
Cheers
Terry
terryhendicott
If you can share them, we need the two data files.
Cheers
Terry
attached to this post you can find the two files.
Thank you
terryhendicott
Cheers
Terry
