Error when open mathcad file
I have mathcad 15. When I open Mathcad file by double click I obtain an error message:
How can I solve this problem?
Try the following. Right-click on the file and then select "Open With" -> "Select Program" -> "Browse" and point to the application "mathcad.exe" from this folder - "C:\Program Files\Mathcad\Mathcad 15".
smilani1-VisitorAuthor
Hi vladimir,
I already try to set it but the result is the same.
I think that is not an associativity problem but an internal software program.
I read that other user have the same problem, but I don't find the fix.
Regards
S
What version of Mathcad 15 and Windows OS are you using? Install the latest Mathcad 15 M045 service release:
http://www.ptc.com/product/mathcad/free-trial
http://www.ptc.com/product/mathcad/free-trial/thank-you
To run Mathcad 15, the following Microsoft components are required:
  • Microsoft .NET Framework® 3.5 or later;
  • MSXML 4.0 SP2 Pareser and SDK (this exact version of MSXML is required);
  • Microsoft Data Access Components (MDAC) 2.8 or later.
Does the error occur whenever you start Mathcad or only when you try to open this specific file?
Not when open mathcad but when I open a mathcad file by double click on the single file.
When I select mathcad shortcut I don't have any problem.
can you open problematic file from running mathcad ?
MH
