Evaluate values in two Matrices
How do I evaluate each element in two matrices of equal sizes (4 rows x 5 columns) and then return the maximum value into a new matrix? I want to evaluate each element with the corresponding element on the second matrix and produce a new matrix. Thank you in advance for your help with this!
The attached file should help.
Following on from Werner's example the code could be contained in a simple nested for loop program.
So if we go into programming, lets make it complete and create a utility function.
Nicely done
