8-Gravel
Excel file in Mathcad 14
Hi all!
I'm trying to embed an excel file in mathcad 14 using the    insert--> component--> excel file--> "create from file" (display as icon).
All I want is data from A1:A166053  (i know it is a lot of data ), this data represent the significant wave height since 1957.
After I "create from file" I select 0 input and 1 output and then define the range i need. When this is done the icon appers in mathcad and I define the
name. In this case "Hs". Then the error message "The range value specified is invalid" appears...What am i missing??
Regards
Sigurd Næss
23-Emerald V
What version of Office/Excel?
Note that Mathcad 14 is around for some time, and MS have changed Office significantly since then. Mathcad 14 may not know how to handle.
To be independent: Copy your one-column data to a Notepad file, save as .PRN file and use READPRN to read the data.
Then you can process.
23-Emerald V
The other way 'round is to make sure your excel data is saved as office 2003 or earlier...
snã¦ss8-GravelAuthor
8-Gravel
Thank you for the answer i will try this tomorrow.  I have office 2010,
Regards
Sigurd
8-Gravel
Hello again!
First! Thank you all for contributing to my question, things got a bit too advanced for me towards the end, but all is appreciated
I managed to import the data, I included a new column which represents the year the wave height was collected. Is there a way to find out the max value for each year, and have that returned in a nice table?
I tired a bit myself, extracting submatrix for a year and finding the max value for that submatrix. But I couldn't make Mathcad do all the steps from 1957-2014.
Hope I expressed myself correct and I appreciate all the help I can get
Regards
Sigurd
23-Emerald V
Sigurd Næss wrote:
Hello again!
Regards
Sigurd
Hi Sigurd,
Is this of any help?  There's another approach in the worksheet that uses a few of my utility functions to extract the data.
Could you please post the data file as well?  It will help verify the solution.  Thanks,
Stuart
8-Gravel
Wow! That looks great!
Sigurd
