Excel output units
I am creating an excel table using the Excel component in Mathcad Prime 3.1.
I am exporting the flow rate (which by default is m^3/s). I want it to be input into the table as l/s.
Is it possible to do this without completing your own multiplication on the number (i.e. multiplying by 1,000 or whatever it is to convert m^3 to s).
Andrew
23-Emerald I
Try dividing by the units you want.  This makes the values correct but unitless in Mathcad.  Since EXCEL doesn't care about units . . .
