7-Bedrock
Expand equation to higher order Taylor series
The mathcad series commands generated an order 6 series. Is it possible to expand the equation to a higher rate?
James
23-Emerald V
Hi James,
Yes, just write "series,n" where n is the order you want.
The beginning ...
The end (many pages over to the right!).
Stuart
file:///C:/Program%20Files/PTC/Mathcad%20Prime%207.0.0.0/Help/en/index.html#page/PTC_Mathcad_Help%2Fto_expand_an_expression_in_a_taylor_or_laurent_series.html
OR
https://support.ptc.com/help/mathcad/r7.0/en/index.html#page/PTC_Mathcad_Help%2Fto_expand_an_expression_in_a_taylor_or_laurent_series.html
Exact result by replacing 1/3.33333 by 3/10 :
23-Emerald V
I can see it's going to be one of those years already.  I normally post Help links from a tab that goes to the PTC site.   This time I pressed F1 and forgot that it used the local help (and I didn't check what the output looked like).
I keep saying I need new glasses, but maybe a new brain is in order too.  ☹️
