Oct 27, 2018 10:10 PM UTC
explicit ...is it possible only short numbers ?
is it possible that explicit shows only numbers and short numbers like 2-3 digits
Oct 28, 2018 1:29 AM UTC
You may consider using "explicit" in conjunction with "float,3" or the like but you have to be aware of the fact that this also affects the precision  of the whole calculation.
Oct 28, 2018 5:11 AM UTC
Attach please the sheet or its short variant.
23-Emerald V
Oct 28, 2018 7:10 AM UTC
Sometimes it helps if you work with ONLY exact numbers. That means prevent using reals, use integers instead, change your 0.12 to 12/100, 1.8 to 18/10 etcetera.
Oct 28, 2018 7:55 AM UTC
I do like this - and no problems:
mortenx1-VisitorAuthor
Oct 28, 2018 9:07 AM UTC
and my other question, that is it possible that explicit shows only numbers not units ?
23-Emerald I
Oct 28, 2018 1:24 PM UTC
explicit is a symbolic command.  Symbolics doesn't understand units, they get treated as variables
