export f(t) values to excel sheet
hi i need to export the values of f(t) to excel.
although i tried excel component it doesn't work.so can you pls recommend this
its my part of my dissertation.
terryhendicott
Hi
Use WRITEEXCEL.  Help file shows how to use it.
dheen1-VisitorAuthor
its not working.
23-Emerald I
What version of Prime?  3.0, 3.1,  4.0?
Can you post a sheet that does not work?   (May have to Zip it first.)
23-Emerald I
Might be you need to use vectors rather than range variables, but look at the attachment:
  • excel component
  • two input expressions
  • Double-click in the component, it opens in EXCEL
  • can do a "save-as from EXCEL
