Exporting a matrix to Excel with VBA
I would like to export a complete matrix from mathcad prime 8.0 to an existing Excel file and in a specified range of cells. While reading through some older posts on this topic, I got the feeling this shouldn't be too hard. I am, however, completely new to VBA. For now i have the following lines:
Sub ExportMatrixToExcel()
Dim MCApp As Ptc_MathcadPrime_Automation.Application
Dim WS As Ptc_MathcadPrime_Automation.Worksheet
Set MCApp = New Ptc_MathcadPrime_Automation.Application
MCApp.Visible = True
MCApp.Open ("E:\Mathcad\test.mcdx")
From here i would like to export the matrix in the mathcad file to my Excel file. The dimension of the matrix is 5x5 and let's say i want to place this matrix in Excel starting at C5 and ending at G9.
Is somebody willing to help me with this with a general example?
Thanks in advance
LucMeekesAnswer
23-Emerald V
WRITEEXCEL writes data to an excel file. If it doesn't exist, it creates it. If it exists, it overwrites existing data.
Some remarks:
- It doesn't seem to be able to create new sheets in the Excel workbook, you're limited to 3 sheets when the file is created by Prime.
- the function of the arguments 'rows' and 'cols' is unclear.
23-Emerald V
Why not use the Excel interface functions of Prime?
DFrancke4-ParticipantAuthor
Hi Luc,
I gave this a try before considering VBA. The thing is that the "WRITEEXCEL" function can only write data to a new file, which also only seems te be active for a specific Mathcad worksheet right? This would not be possible for me since I need to export data I calculated to an existing Excel file of my client.
LucMeekes23-Emerald VAnswer
23-Emerald V
Some remarks:
