Exporting results to EXCEL and locating the file in sharePoint
Hi there,
I have 2 questions:
1) Can I choose the location of the excel sheet in Sharepoint of our company ( using link) like I did below? I need the file in company data not personal PC.
2) How can I generate the same excel sheet for all the results instead of generating new sheets for each ?
The sheet is attached below , page no 4 , using Prime 9
If the sharepoint directory is a string in quotations and a slash/backslash added at the right hand end the following could work.  I know it works on network drives.
If you name both the path and file as below Prime will always use this file name irrespective of Prime filename.
Community Moderator
August 2, 2024
Hello @YA_10963798,
 It looks like you have a response from a community member. If it answer's your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
