Extracting Data from MathCAD using VB examples, tutorials or sth like templates?
Hi there,
i searched a lot in this forum but couldnt find sth which works.
Actually i would like to send with vb some variables into my mathcad 15 sheet and show just the results. If there is any way to show also the graphs, would be top.
Im not good at vb so i thought like a template or an example which works and i could change the code according to my needs.
Thanks in advance for a solution.
RichardJAnswer
Sorry, but as I said, I did not write it. I don't have the time to install VB.NET and debug it.
23-Emerald V
Have a look in your Mathcad (15 or earlier) Help => Developer's Reference  => Accessing Mathcad from within another application.
There are examples of using VB with Mathcad. (at least, in Mathcad version 11 this info is avialable).
I did not writre this, Viacheslav Mezentsev did. I have not tested it, but he knows what he is doing. I'm just passing it along.
musa19881-VisitorAuthor
Thanks for the answers.
@RichardJ
Hmm it is not working. I opened it with VB 2010 but it shows me an error when i run it. It shows me in the code that myA is not defined but actually it is there -.-*
RichardJ19-TanzaniteAnswer
