Extracting Rows Based on Array Values
As per the original Post..
Luc…
This is very interesting and elegant.  It turns out that I have an application for your method as well.  However, I have Prime 5 and can't read your Prime 6 file, and the image you posted is cropped on the right end.  Could you post a full image so I can recreate your solution in Prime 5?  Thanks.
Fred
LucMeekesAnswer
23-Emerald V
Sorry, that was a Prime 6 file. Now it is saved by Prime 4.
23-Emerald V
Hi Fred,
Here's a compatible version for you.
FredLusk14-AlexandriteAuthor
Luc…
Thanks, but I still can't read it.  I have Prime 5.0.0.0 and when I attempt to load your worksheet, I get an error message that says that this file "is from a more recent version of Mathcad."
Fred
LucMeekes23-Emerald VAnswer
23-Emerald V
