F - distribution trouble
Hello everyone,
I have some trouble with a function dF(x, d1, d2). I would like to aquire this way p value from F distribution for a known sample with identified F value.
Number of independent variables: 2
Number of dependent variables: 1
Sample's size: 20
F value: 16.8833
I implemented data to formula: dF(16.8833,2,17) and got a result 3.064 *10^-5. But this is not correct for my needs, because the desired value is 9.15*10^-5.
When I calculate it in reverse way through formula qF(1-9.15*10^-5,2,17) I got 16.8833. Can you explain me what I am doing wrong?
Werner_EAnswer
It may help if you would attach your worksheet.
You may also additionally consider explaining why you think that Mathcad's result is incorrect.
Werner_E25-Diamond IAnswer
Maybe is correct, but this is not what I would like to get.
Mentioned formula qF calculates critical value from F - distribution for known level of confidence, what I would like to do is to find level of confidence with known critical value, so do it in a reverse fashion for multiple regression analysis (do not ask me why I do it step after step ). Presumably I messed something up with degreess of freedom. With t student everything was working in comply with scheme, which I presented above.
Shouldn't you rather user the cumulative probability pF() instead of the probability density dF()?
