Factor a simbolic expression
Hi. I have the folowing expression in mathcad:
and i want'it to look like this:
How do i do this in MathCad?
Thank you
Werner_EAnswer
Use the symbolic coammnd "factor".
You can't have a superscript as part of the name. Guess it would also be too easy to mix it up with exponantiation anyway.
Werner_E25-Diamond IAnswer
How did you insert in the expression that "factor" command?
Thank you
Either use the Symbolic Keyword Toolbar
or type the keyboard shortcut Strg & Shift & . and type in factor manually.
Then right klick the expression and chose "Hide keywords" and chose "View Evaluation As" - "Equal Sign".
