failed to launch server application
I have been running Mathcad 14 under Vista for a short time, but now I keep getting the error message "failed to launch server application". This only goes away after being clicked several times, but reappears as soon as I try to anything on the sheet. Now I can't do anything at all except click off the message.
How do I get out of this loop?
Apparently, installing the update m011 did the trick.
This is what is posted on the Mathcad 14 support site,
Description:
After installing Mathcad, the user receives an error message, similar to the one stated above, when launching Mathcad 14.0.
Resolution:
1) Please check Add/Remove programs for the following:
Microsoft .NET Framework 2.0
MSXML 4.0 SP2 Parser and SDK
If you cannot locate the pre-requisites listed above, they can be downloaded by clicking the appropriate link(s) below.
http://www.microsoft.com/downloads/details.aspx?familyid=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid=B44A0000-ACF8-4FA1-AFFB-40E78D788B00&displaylang=en (64 bit version)
http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&DisplayLang=en
2) Repair installation of Mathcad 14.0 or M010
**Disable all security features/anti-virus/anti-spyware**
With Mathcad 14 CD in the disc drive:
A) Go to Add/Remove programs
B) Select Mathcad 14 and press the "Change" button
C) Continue through the prompts and select the "repair installation" option
After Repair installation:
3) Re-register the Mathcad 14 dlls.
Go to Start -> Run -> Browse to the Mathcad.exe file in the the C:\ProgramFiles\Mathcad\Mathcad 14 directory.
After pointing to the mathcad.exe file, select "open" go to the end of the string in the Run dialog box, and hit the spacebar once after the � and type in "/register". It should look like this in the Run box:
"C:\Program Files\Mathcad\Mathcad 14\mathcad.exe" /register
Mona
