3-Newcomer
file could not be opened
I have a file made in prime 9 and when I tried to open today and I could not open. I have copied this file from an original file. I made a minor update on the copied file but I could not open while the original, I could.
I attached the file herein for reference. Thank you.
The file somehow got corrupted/truncated. Unfortunately this happens quite often when using Prime - especially with larger files which contain lot of pictures.
Find attached what I was able to reconstruct - but there seems to be a lot missing.
So it may be the better option to take the older file and do the minor updates again.
3-Newcomer
Thanks Werner. Indeed, there are a lot of items that are missing.
where is your file stored? In directory located on local disk?
3-Newcomer
Hi Martin,
The file is stored in the local disk which is part of a one drive.
Lloyd
@LS_8153366 wrote:
Hi Martin,
Lloyd
I guess that working with Mathcad file saved on OneDrive disk is not safe.
