File Grayed Out and Can't see
I have a file done on version 14 and I try opening it on version 15. I's grayed out unless I zoom in like 200%. Is there any button under some menu turned on and I don't know about it? Any help'd be appreciated.
Thanks.
RichardJAnswer
M020 is the service pack. Download M045 from here, and see if it fixes the problem: http://www.ptc.com/engineering-math-software/mathcad/free-trial/thank-you
23-Emerald V
Thanks.
I presume Mathcad 15 otherwise works OK and you don't have problems with display otherwise (such as 3D plots not showing because Borders are on)?
Does it contain graphics in the header or footer, or have a background colour set?
Can you copy bits out of the file (at 200 % zoom) and paste them into a new worksheet OK (at 100 % zoom)?
Can you post the file for others to have a look at?
Stuart
tmin1-VisitorAuthor
I copied bits as you suggested to 100% zoom and it's a lot of work but it works for now. Didn't think about it. thanks..
What's the full version of 15, including service packs?
tmin1-VisitorAuthor
cant tell ya. it just says Mathcad 15.0 (M020 [MC15_M005_20101105])
RichardJ19-TanzaniteAnswer
Can you attach this Mathcad worksheet?
tmin1-VisitorAuthor
export control problem. I don't know if I'm allowed. for now, I copy and paste to a new file to work on it. it works.
thanks..
