Fill any shape area using CreateMesh() ?
- 4 replies
- 1591 views
- Translate All
To all,
I am looking at using the CreateMesh() if not using a “constant" X & y range. I had a look at the “amazing image in mcad” e-book but for some reason none of the hyperlinks are working – just images!
Is there a way of plotting a function f(x,y) for a non-constant range of x&y values i.e. not a rectangle. In other words filled the area enclosed by user defined points? See attached for example
Is it possible to fill the area enclosed by the I-shape with function S1
