Find function is not working
I am trying to calculate the following equation for a project that i have.
Nor the find function or the root function doesn't give me the result.
I am currently using the Mathcad Prime vers 7.0.
What can i do?
Thank you!
LucMeekesAnswer
23-Emerald V
Here is an example with the root() function
23-Emerald V
What can you do?
1. Attach the Prime worksheet file, not just a picture.
2. Realise that you have defined Ha, and then want to find it, while Clt and Ho are not defined.
3. Use a solve block the way it should be used in Prime. (Look it up in the help). A solve block in Prime is different from a solve block in (real) Mathcad (15 and before).
Sorry, forgot to add the file.
Here it is.
I have both of the values defined above.
LucMeekes23-Emerald VAnswer
23-Emerald V
