Find function only finding zero as the answer
- 1 reply
- 1571 views
- Translate All
I'm using the find function to find 9 variable with 9 equations. Each of the equations equal zero thus mathcad finds zero as an answer. There should be another answer. I know the find fuction will find the closes answer to the guesses but changing the guesses doesn't make much difference.
I tried to set that the variable are not equal to zero but that didn't change anything. The system is working, if I set one of the equations equals 1, I get 9 non-zero answers.
If anyone has a suggestion to sove the system that would be great.
Thanks in advance,
Kendall
