Finding parameter to fit known eq. to 3 points?
To all,
I am trying to see if one can find a parameter required to fit a known equation to a set of data points. See attached.
I have an equation Q(w,wn,zeta) and would like to see if it 's possible to find the value of zeta required to fit the Q() for a given data set
Test 1:
For a given range of w values, a value of wm and zeta = 0.04, I calculated the Q value, allocated them to a table to “mimic” a data set (not important but it follows how data is provided. I am trying to work “backward” by trying to find the zeta value required to fits Q at the max value. (Obviously mcad must predict zeta  =0.04 !)
I have set up ‘test 1’ as a root() but nothing is return
Test 2:
  Use a subset of a known data set and see if one can find the zeta value required to fit Q() passing through 3 points of that subset
I know that must people will say that I am tackling the problem the wrong way but I have to start somewhere and that why I am looking for advice
Any pointers by the more mathematically inclined out there would be much appreciated
Regards
Do you mean something like in the attached?
Alan
Thanks AlanS. definitely a step forward. I  now understand the mistake I made on my 'test1'
Questions if I may?
1. in the solve block you defined 1 equality.
    Why not 1 equality for each point? See attached for my attempt
2. Why is there no way of plotting the Q() function with the zeta found over the range w? Mind you zeta appears to be too big as it should be <1
Questions if I may?
1. It is an equality for each of the three points. They are in a 3x1 vector, and all three are being compared. Although I used different wn for each point, I suspect that a single wn should be used. Given that there are three points of comparison you could use Minerr to find the best combination of wn and zeta.
2.  You should be able to plot Q as a function of w using a value of zeta and a value of  wn.
Alan.
