Nov 8, 2012 9:40 AM UTC
Floating point error problem in programming
I have done pressure calculations in normal worksheet format and i got results without any error. but it needs to change a value once for every iterations. So i moved on to programming. I compiled the program using while loop and break conditions. After completing and running the program i got error message showing "encountered a floating point error".Dont know how to fix the bug.. Can anyone help me pls?????????
23-Emerald V
Nov 8, 2012 9:47 AM UTC
Somewhere within your loop the deltaP .dc and .r variables are blowing up to the limits of numeric handling (ie, they're in the order of 10307 )
Stuart
23-Emerald V
Stuart
