18-Opal
Foor Loop
Hi all.
Why am I seeing all the extra rows  of Zeros?
I just want to see 4 to 8
Thanks for the help.
terryhendicott
Indexes into matrices start at zero
terryhendicott
What version are you using?
You need to include the file.
18-Opal
Attached now
We see neither zeros nor 4's or 8's!
Obviously you forgot to add a picture, or, preferably, your worksheet.
My crystal ball thinks that the reason for your problem is that you use a vector or matrix which was already defined before with a larger size or that for some reason an element with higher index was unintentionally assigned.
terryhendicott
Not necessarily, as the picture below shows, but it sure would make more sense to leave the default ORIGIN=0 (or rather set it to 1, but sure not 4)
