Format for document/saved date
Hi, I like to have the date in header automatic, therefore I use the Saved date under Document.
I would like to add a format for "Saved date" according to standard ISO 8601, that is YYYY-MM-DD. Is it possible or are there any workarounds for this?
Kind regards/Emelia
As far as I remember this is a long standing demand from right when Prime introduced headers and its not understandable why this date format is not supported. As far as I know there is no workaround (other than manually typing the date, of course).
If you think it could help, you may report it to PTC and add an idea in the Mathcad Ideas cemetery -> https://community.ptc.com/t5/Mathcad-Ideas/idb-p/PTCMathcadIdeas
ttokoro
Not in header but body of the Mathcad sheet, you can use these functions.
Solved: date and time - PTC Community
t.t.
