Nov 7, 2016 3:55 PM UTC
Function returning two vectors, but with different units
Hi everybody,
I am trying to build a function that should give back two vectors (and that is not the problem), only those vectors have different units.
The only way I can imagine is to adimensionalize the vectors, using UnitsOf (or SIUnitsOf) and the assemble them in the array of vectors that I want to get back.
Somehow this it is cumbersome and error prone, since outside the function I will have to multiply back the variables by their units.
Thanks a lot
Best regards
Claudio
23-Emerald V
Nov 7, 2016 4:12 PM UTC
Hi Claudio,
Unfortunately, Mathcad 15 doesn't allow mixed units in an array, and adimensionalizing them is (almost) the only way to get round the problem ... When I say almost, you could try returning both vectors in the units of one of the items and then correcting the units on the other one (at least, it reduces your error probability by 50% !).
This is one of the few aspects in which Prime is better than M15, as Prime can handle mixed-unit (well, mixed-dimension, technically) arrays.
Stuart
23-Emerald V
Hi Claudio,
Stuart
