Function that shows the equation that was used in a satisfied condition
I'm not sure if my subject is correct. But I'm looking for function to show the formula or equation that was used in a variable especially if there are conditions that was used in the said variable. see example below. Variable Leh has 2 formulas that was conditioned based on the value of variable nv. if the first condition was satisfied, i want to display the formula instead of the result of the formula. Thank you
23-Emerald V
Probably your best bet is to return the expression as a string, if you can put up with the lack of subscription (and can tolerate, say, using a period (".") to indicate start of subscripts).
You may be able to play around with the symbolic processor (SP) to get the result you want, but invoking the symbolic processor both slows things down and may lead to undesirable side effects.
Stuart
hi, thanks for the reply, can you so me how to do it or can you give an example?
23-Emerald V
Terry's given you a Mathcad 15 example of returning the formula as a string.   Here's a Mathcad Prime 7 example using the symbolic processor.  I haven't got M15, but I *think* it should work in M15 if you use different Math Styles for the "formula" and "working" expression.
Stuart
terryhendicott
23-Emerald V
How about:
