11-Garnet
November 24, 2012
give a default value when a variable is not defined or "on error"
Probably my is a trivial question. I started using reference files to take advantage of repetitive calculations. So the scenario could be like the following.
  • Main Worksheet [1]: defines var1; var2, then it references file .mcd Worksheet [2].
  • Linked Worksheet [2]: expects var3 and gives outputVar1.
I would like to put in [2] a line of programming that if no var3 is defined, then var3:=0. Yet I tried "on error" function, but I realized that it does not work in this case
Is there a way to assign a value to a variable when it is "on error" AND when it is "not defined" above (in my case in the main worksheet)?
Thanks for any tip.
RichardJAnswer
It's not a trivial question. If an expression contains an undefined variable then the expression is not evaluated. Therefore there is no Mathcad expression that can trap an undefined variable and assign a default value. There is a way to do this, but it requires a kludge.
RichardJ19-TanzaniteAnswer
11-Garnet
November 24, 2012
Thanks Richard,
amazing job. I did not know it was "no a trivial" question at all. As I admire your skills, I fear that for the time being I will not rely on Visual Basic.
The trick that I meanwhile envisage is to create at the very beginning a linked worksheet initializing all possible variables with a default value, so to leave below the possibility of changing or not declaring them any more. In the above scenario:
  • Main Worksheet [1]: ...wait before defining
      • Linked Worksheet [0]: declare all possible variables with a default value.
    • proceed in [1] to define (again) var1, var2, etc. as you like.
      • Linked Worksheet [2]: expects var3 and gives outputVar1. (Now it is ok because of Worksheet [0]).
    • retake outputVar1 in the main worksheet.
Worksheet [0] becomes so to speak a Contents of variables.
Update.....Oops but it did not work. I realize that I am not able to pass on the definitions from worksheets that are referenced. That's a pity. I hope to be wrong! And I was wrong: there is no update with reference worksheets, so changes are evaluated (and accepted) only after a restart.
11-Garnet
November 25, 2012
Richard,
I saw that you gave an answer at a post in 2007,
http://communities.ptc.com/message/85673#85673
that it was asking more or less a similar question.
You gave the following link for further reference:
http://collab.mathsoft.com/read?80805,63e#80805
which is now not reachable. Was it a shorter version of the VBasic that you posted here?
I tried to reduce your code to my needs, but I am a very novice in VB and I would like a bare and bones example.
The workflow I gave above has a drawback: the linked file [2] cannot be used as a standalone worksheet because of the undefined variables. So I am back to the original question.
A solution without Visual Basic coding
At first a workaround I thought was to make a manual "switch" to hide or show in the linked worksheet [2] the assignment of variables (according if they are defined already or not in the container worksheet [1]). But I did not find an elegant way to accomplish it.
Then I come up with the following solution. It relies on the build-in "inN" assignment, with N--> 0..9.
So if one assigns in file [2]
var03:=in0,
it does not give an error. But it leaves Var03=0 if "inN" is not assigned above. From it one can build a conditional line, to pick up the value in worksheet [2], if variables in0, in1, etc. are not assigned in the worksheet n.[1].
Richard, it would work also with your example, if dataC was assigned the name DataC:=in0. I hope the trick is helpful to someone.
