Given/Find Solve Block "Variable Undefined"
- 2 replies
- 1969 views
- Translate All
I'm working on a heat exchanger analysis problem and was going to use a Given/Find Solve Block to solve a system of equations. There are two heat exchangers in series. Near the top of my mathcad sheet I input the given values for the hot inlet fluid temperature and cold inlet fluid temperature, the physical properties, and mass flow rates. I then list my initial guesses and create the Given/Find block but get an error when using the Find function. Any hints/tips/tricks/concerns?
Thanks!
