Graphs title and traces name as variables?
To all
Is there a way of having the title of a graph and the description of the traces as variables? I am looking for a way of automatically up-dating these based on teh data selected
Regards
JXB
I assume you are dealing with Mathcad 14/15, as in Prime there even are no titles or legends.
The answer to your question is - unfortunately no.
There may be workarounds like using string variables which can be set depending on data selected or text box components controlled by VB Script, but they probably all are either of mediocre quality and/or (too) complicated.
Mcad 14. simple things like that would make one's life (a lot) easier. Thanks for the reply
Yes, agreed on.
I often wished I could change number of grid lines/intervals for numbering with variables - the automatic isn't that perfect and static values don't work with varying plot ranges.
