Green's Function - Mathcad Prime 3.0 or Mathcad 15
Hello Folks!
I am working on the solution of heat conduction problems with time-dependent boundary conditions. I am trying to find out if the Green's Function is available in Mathcad Prime 3.0 or Mathcad 15. So far I haven't been able to find it, but it may be included under a different name. If someone has used this in Mathcad, their help will be greatly appreciated.
Thank you!
You can find some Mathcad worksheets of application of Green's functions here: http://web.archive.org/web/20100626115627/http://mse-pma1.eng.ohio-state.edu/~peterand/mse862/schedule.html
Hi Vladimir!
Thank you so much for your answer. It is clear to me now that Mathcad does not have a built-in Green's function, but we can simply construct one, just like in the example you provided.
That is correct.
