Help
Appreciate if you help to fix the error in the attached sheet
Thanks in advanced
terryhendicott
Enclosed is latest sheet version 2.
Cheers
Terry
terryhendicott
On the right you have images taken from a Mathcad 15 or earlier worksheet.
Why don't you use the XMCD,MCDX Converter found on the Prime Ribbon at Input/Output to convert the original file to Prime?
Cheers
Terry
terryhendicott
Enclosed sheet.
I have put in the indices used in the original worksheet.
I have corrected a formula.
Still a problem with two equations but I will work with them some more.
HHHH1-VisitorAuthor
Really I'm so grateful sir, I'm waiting for your nice work
terryhendicott
Cheers
Terry
