ttokoro
Help-2. Circle diagram.
Help 2.
How to solve circle diagram problem by Mathcad ?
Symbolic maximum problem.
T. Tokoro.
ttokoro
ttokoro21-Topaz IAuthor
May be Mathcad can more good solution. T.Tokoro.
t.t.
23-Emerald V
Ah, I see you found it too.
23-Emerald V
Like this?
Luc,
Why does my MathCad 15 not calculate your worksheet?
regards, Volker
ps.: isn't it ?
23-Emerald V
Don't know. I see no error (no red) in what you post.
- You forgot to hit the F9 key, to have it calculate?
- You might want to inspect what it finds as symbolic results for the Zm and Zr functions, by adding a symbolic evaluation in their definition:
-MFra-
Hi Tetsuroh Tokoro.
I tried to interpret your wishes, but in my own way, I hope my solution satisfies you:
Best Regards
F. M.
ttokoro
Thanks all.
We must solve the electric circuit with r is real (not Imaginary) and r>=0.
Sometimes using Mathcad I forgot it.
T.Tokoro.
t.t.
-MFra-
Hi, Tetsuroh,
I considered r always real and positive, so I did not understand your last statement.
Best Regards
FM
23-Emerald V
Corrected and expanded:
ttokoro
This is not smart answer. But, anyway, it was solved.
T.Tokoro.
t.t.
