Oct 4, 2015 10:26 AM UTC
Help - Excel Embedded Mathcad - Video
Dear All,
I'm having a problem with the excel object display in mathcad.
As you can see in below video, I can not lock the excel view, when click outside the excel object.
I would appreciate your help with this issue.
Thanks in advance.
Oct 5, 2015 2:38 PM UTC
When I try this it works fine for me. Which versions of Mathcad and Excel are you using?
7-Bedrock
Oct 5, 2015 3:06 PM UTC
Excel > select area > copy > paste in Mathcad
Oct 6, 2015 6:47 AM UTC
Richard Jackson: The mathcad version is 14, and the excel version is 2010. Before this issue was not happening, and suddenly without any obvious cause it started.
Quinn M: The excel file is a complex VBA program that needs to be runned from mathcad (excel embedded), but i will try!
Oct 6, 2015 7:00 AM UTC
Quinn M: The excel file embedded as per your suggestion (Excel > select area > copy > paste in Mathcad), will not allow an input and output from mathcad to excel, and from excel to mathcad. Correct?
