help!.. how can i plot a 3d surface graph from 3 columns of data i've got in excel?
hi, this can't be hard can it?.. am new to mathcad and am trying to import 3 columns x12 rows of excel data by copy/paste into a table and/or a matrix etc with the intention of plotting on a 3d surface graph
...I can paste the values into the mathcad matrix ok but can't seem to assign a variable name to the matrix... so graph can't load it (nor can anything else refer to it I suppose)
...the table rows/columns aren't read in from the excel data - they are presumed 0, 1, 2 etc - so axes are preset to 0, 1, 2... rather than 1st 2 columns of data in excel file - graph just plots 3 columns of data imported as if they were functions f({0, 1, 2}, {0, 1, 2})... which seems a bit dim ...(my 3 columns in excel are the x, y, z) function should be {excel col3} = f({excel col1}, {excel col2})
I must be missing something obvious - can anyone help?
lots of thanks
23-Emerald I
In version 15, it's not hard:
  1. select the data in EXCEL and copy
  2. In version 15, type your matrix name and :=, then paste.  And you have your matrix.
In Prime, I believe it's a bit more complicated.  Insert an EXCEL component, paste the data into the component, and define your matrix from the component.
23-Emerald V
lots of thanks
dnorman1-VisitorAuthor
thanks for this - it's a brilliant reply!..
it's almost exactly what I wanted to do... but just one last thing... the x, y axes are labelled according to the row/column number of the data - can the x/y axes range be labelled from the min/max x, y values in the matrix array instead? (i.e. if the x value was say temperature, it would make sense to have the x-axis showing the temperature range, not just which row/column the data came from...)
ok.. hope clear to understand
23-Emerald V
seperate each column with a column and wrap parentheses around the 3 columns.
Stuart
