help please
help please
any one know if there is a optional button an be inserted in the work sheet
to make it more clear
for example if i want to make a sheet for analysis a beam with tee section ..... some times it's is rectangular or tee section i want to write the both code for analysis and make a button to click on it when it's R.S and click on the other when it's Tee
thank you
Which version of Mathcad are you using?
melshab1-VisitorAuthor
Mathcad Prime 3.1
Then sorry, but no such feature is available
That is possible if you are working in Mathcad 15, not if you are working in Mathcad Prime. Exactly how to implement it in Mathcad 15 would depend on what you want the button to do.
Hello Muhenid,
here is a small example for a "decision making" button in MathCad 15 worksheet. The beam deflection is claculated for different beam shapes.
Raiko
RaikoA.NonRaiko Milanovic Thank you
