Help with excel components
I need help with excel components. I have tried so many tutorial videos, but nothing has worked. Please comment very easy instructions for how to insert data from excel into an excel component. Thank You!
Mathcad 15 or Mathcad Prime?
Why videos - isn't the built-in help comprehensive and to the point enough?
Which specific problems do you experience?
If you just want to import some data into a Mathcad sheet, you may also use READEXCEL() to do so (again, look it up in the help). It depends upon your needs if this would be an option.
I guess for more help ypu will have to be more specific and most import also answer Valery's question - are you using Mathcad(15 or below) or Prime (1..3)?
All I get is the blank excell box. Now what?
23-Emerald V
Now what?
That's simple. Now you should ask yourself: "Did I provide enough information for getting actual help on my problem? Did I attach my Mathcad worksheet, and the excel file it needs to work with? Did I clearly explain what I wanted to accomplish, and where it failed?"
It's so simple.
