Feb 3, 2013 6:03 PM UTC
Help with List Box persistance Script
Hi all,
To start with I am not sure if I am posting under the right catagories, but here goes.
I am having trouble making my List Box selection persist when I re-open my Mathcad file. The List Box data is initially loaded from a text file and a selection is made from the list. It seems to be doing the right things when I make the initial selection and appears correctly in the Worksheet Properties Custom Tab, I then save the file and re-open it, but the initial selection doesn't re-appear!!!! I have been trying to use the various threads previously posted over the last year or so and they have been very helpful so far, but as hard as I try, I just can't get the final bit cracked.
I should add that I am not that familiar with VBS, I tend to use bits of script from elsewhere and modify to suit, quite often by trial and error.
I have attached my offending files and any help would be greatly appreciated.
Ned
Feb 3, 2013 10:40 PM UTC
There is a listbox here: Saving the state of controls.zip that does what you want with only a very minor modification.
If you are saving the state of the control in the metadata you cannot save the file in .mcd format. It does not support metadata. Use only .xmcd or .xmcdz.
NedMoran1-VisitorAuthor
Feb 4, 2013 2:19 PM UTC
Thanks very much Richard, this is exactly what I want, I was struggling a bit here. I will also study your `Saving the state of controls.zip` when I get a few minutes.
We are actually using Mathcad 15 here at work, I saved the file as Mathcad 11 not knowing which version was best for this forum and not realising that metedata wouldn't save in this version.
Thank you for your time once again.
Ned
