help with mathcad converting matrix results into scalar or any other way to do this
Hi there, need help, i have calculated values of L and R using rnorm function for 1000 intervals with the mean values and the standard deviation values of L and R. The results are in brackets so i assume it is a matrix. Now need to check when L>R and count, i was using if function but needs a scalar result and L and R are not, any ideas?
23-Emerald V
Do like this:
etc.
Note that the function result is the result of evaluation of the last statement it executed before ending (unless error), or whatever you supply as argument to a 'return' statement.
So if you need the vector with the Fail results, put
As the last statement.
fjuarrero1-VisitorAuthor
thanks Luc, will try it
-MFra-
Might it not make more sense the comparison of  the arithmetic means of the data values?
thanks to all, will try the options
