Sep 10, 2024 8:19 AM UTC
Help with moment and shear force diagram
Hi
I have issues trying to plot the Moment and Shear Force diagram of the following case. Any help is highly appreciated! 🙂
Werner_EAnswer
Sep 11, 2024 12:05 PM UTC
Here is a simpler workaround which does not modify your definition of V(x).
Actually you don't have to split the integral at x=L/2. Any position lower than x=9.52m would work OK.
Sep 10, 2024 8:37 AM UTC
Maybe this will help:
Horst Werkle; Horst Werkle; Silke Michaelsen; Wolfgang Francke; Heiko Denk; Fabian Gerold; Günter Lumpe; Gunnar Möller; Günter Schulz:
Mathcad in structural engineering
2012, ISBN: 9783834882387
It is written in German and contains a CD.
Derbigdog
Sep 11, 2024 12:52 AM UTC
Here is a worksheet that can help you.
Sep 11, 2024 5:37 AM UTC
Thank you, but I don't want to derive the moment and the shear force diagram since I already know the functions. I want help with the plot.
23-Emerald V
Sep 11, 2024 7:42 AM UTC
Then attach your Prime worksheet with a clear description of your problem, and state which version of Prime you are using.
success!
3-Newcomer
May 6, 2026 4:18 PM UTC
VERY NICELY DONE AND MOST HELPFUL
GW
