Help with READEXCEL
I have Prime 3.0. When I try to READEXCEL all I get is this It is not reading data in to matrix. Can someone help? Thanks in advance
Without seeing the worksheet I'm guessing a bit, but the expression you show is not assigned to a variable, so Mathcad will not execute it.
