Oct 8, 2021 2:21 AM UTC
Hide Variable in Prime
I would like to hide the variable name and only show the result of an equation.  I've seen several ways to do this in MathCAD 15, but we've switched over to Prime.  Is there a way to do this in prime?
For my specific application I'd like to show the result of a previously evaluated equation in line with some text so that my wording incorporates the result of my math.
Oct 8, 2021 5:45 AM UTC
It is about the implicit operatot?
Oct 8, 2021 8:55 AM UTC
About "explicit" and "clear.sym" function to clear the symbolic values of all variables: https://support.ptc.com/help/mathcad/r7.0/en/#page/PTC_Mathcad_Help%2Fexample_explicit_calculation.html%23
23-Emerald V
Oct 8, 2021 3:36 PM UTC
Could you post an M15 example of what you'd like the output to look like?
Stuart
(I sometimes use the format function to do what you are requesting, but the display of strings makes it look "ugly" - which is often fine, but sometimes quite annoying to look at, as this Mathcad Express 7 worksheet attempts to show:
97323a068a3897ae22734b4e6074bc0b
He don't want much, do he?
Oct 8, 2021 7:08 PM UTC
What I would like to do is, in Stuart's example, is omit the str(a,0)=  and only include the "my simple variable v has the value 9.99, which "is" nice".  That way you can include results naturally in a text field without the somewhat distracting variable name.  I think this was possible a couple of different ways in 15.
