Highlighting color palette (more colors?)
Hi.
The choice of colors seems very limited. Is there a way to get a bigger palette, to have more colors?
Regards
Lukas
LucMeekesAnswer
23-Emerald V
I assume you're referring to Prime. Solution: Use Mathcad (15).
LucMeekes23-Emerald VAnswer
23-Emerald V
What kind of software in todays world limits the amount and kind of colors that a user can use? Even MS paint is more robust then in that regard. Seriously considering going back to Mathcad 15. Sucks bcos lots of time and resources have been invested to have our worksheets changed to Prime but Prime is truly a big Mess. I will keep whining here until one day PTC does something. Even if its in 100 years from now :(.
23-Emerald V
"What kind of software in todays world limits the amount and kind of colors that a user can use?"
Essentially ALL software does that, simply because software uses digital processors with words with a limited bit-length.
As Luc hinted at above. Prime does not have 'define custom colours' option.
Mike
lkostorz1-VisitorAuthor
A drawback then..
Ok, thanks.
Just one of many
