histogram with text in the x axis
Dear all,
I would like to plot a histogram with text on the x axis.
Moreover I would like to perform a calculation without repeating the formula many times.
The two points are highlighted in the attached mathcad file.
Thank-you very much for your support.
Best Regards.
Enrico
Werner_EAnswer
Its a bit elaborate but it can be done without text boxes or the like
Here's my best try:
You probably can avoid the magenta line at the bottom if you arrange the plots so that the black bars are plotted last.
ebelmonte1-VisitorAuthor
Dear Werner,
Thank-you very much for your replay.
How can I plot the results in a histogram?
Best Regards.
Enrico
23-Emerald V
eeh... Use the histogram function in combination with a plot...?
