Oct 19, 2015 8:04 PM UTC
How can I convert MathCAD Prime files (.mcdx) into MathCAD 15 files (.xmcd)?
I downloaded a zip file from the PTC community from the following URL.
     ·Finding the Shear Force and Bending Moment Along a... - PTC Community
After downloading and unzipping the file, I have a file extension of .mcdx (relations_between_distributed_load_shear_force_and_bending_moment.mcdx).  I tried to open this file in MathCAD however; the file fails to open.  How can I get this file to open?  I am using PTC MathCAD 15.  Should the extension be .xmcd?
Apperently the .mcdx files are for MathCAD Prime.  How can I convert MathCAD Prime files (.mcdx) into MathCAD 15 files (.xmcd).  I have tried simply changing the file extention but that did not work.
Thomas Henkel
Oct 19, 2015 9:35 PM UTC
PTC has decided that there should be no way back (Prime itself is backstep enough).
So you can't convert Prime sheets (mcdx) in real Mathcad format (xmcd or xmcdz).
You even cannot convert Prime 3.1 sheets to Prime 3.0 format (and of course Prime 3.0 cannot read 3.1 sheets).
Oct 20, 2015 4:43 AM UTC
... or can wait for a maple or mathematica package ...
Oct 20, 2015 9:13 AM UTC
But what do you mean?
23-Emerald V
Oct 20, 2015 5:46 AM UTC
But what you can do is open the file with Prime 3.1 express, which you can install for free.
23-Emerald V
Oct 20, 2015 6:15 AM UTC
Mind though, there may be errors in that sheet.
I don't trust the expression for MBC(x) that appears on page 6...
23-Emerald V
Oct 21, 2015 12:25 PM UTC
I have to correct. The expression for MBC(x) is OK.
Oct 20, 2015 6:23 AM UTC
Oct 20, 2015 9:32 AM UTC
