Mar 11, 2015 2:06 PM UTC
How can I type symbol for statistical "mean" value?
Hi All,
Does anybody know how to type "mean" value symbol?
Basically a horizontal line on top of the letter.
Letetr + " = this, but that means an operation (conjugate).
I just want to have the symbol as my variable for statistics.
I'm using MC 15.
Thank you
RichardJAnswer
Mar 11, 2015 4:18 PM UTC
Use the character with a combining overline. In principle you should be able to enter the combining overline using the numeric keyboard, but Mathcad messes up the font mappings so there's no way to figure out what the correct character number is. The only solution seems to be to copy and paste it from the character map (it's character 0305 in hex). This does not work for all fonts, but Arial Unicode MS seems to work OK.
RichardJ19-TanzaniteAnswer
zroman-21-VisitorAuthor
Mar 14, 2015 1:15 PM UTC
Thank you very much, it worked well.
Apr 8, 2016 4:29 AM UTC
Can I use this as a variable name?
I can NOT seem to get this to work other than within a text region.
Kevin
Apr 10, 2016 2:52 AM UTC
Werner-
You are correct in that I am using Prime 3.1
Your trick works beautifully!
Thank you!
